Discussion topic: How do I speak to an agent
This message was authored by: Kirk79
My broadband is not working at home and it's impossible to speak to a human. Can anyone help?
Re: How do I speak to an agent
@Kirk79
Even if you’ve already tried it the first thing to do is use this link to check if there are any broadband outages or issues locally that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
Avatar for Kirk79
Level 0 icon
I don't have a landline to call them and I've run the tests and it says it's working when it isn't
@Kirk79
For your information you do have a Sky Talk landline as it's bundled with your broadband package but you have chosen not to connect an actual handset which is fine and entirely your choice.
In the future if you have a cheap handset you only need to plug it in when you need to call Sky (dialling 150 free) if and when there's an issue.
These are the current methods available for contacting Sky. Depending on your reason for making contact some will be more appropriate than others.
🟡📞 Call Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟡online help via this link
https://www.sky.com/help
🟡Sky Assistant 💬 should also be available via
🟡Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🔹Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of any link is showing the correct flag and change if required. The Sky Ireland phone lines have different operating hours to the UK and are closed over a weekend.
