Discussion topic: How do I get the replacement hub?
Message posted on 10 Mar 2025 10:59 AM
Hi I got the email about the replacement hub because there will be no more security updates. The link does not point to a page how do I update my hub?
Message posted on 10 Mar 2025 01:38 PM
Re: How do I get the replacement hub?
What happens when you click the link on
the email as it did work for me when I used it last month, does the webpage not load ?
Message posted on 10 Mar 2025 08:15 PM
It just goes to the main site - not a specific page about the replacement
Message posted on 10 Mar 2025 08:18 PM
All you can do is to call Sky to see if they can get this ordered for you.
150 is the free number to use from a phone that has a Sky mobile sim in it or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
Try saying nothing when spoken to by the bot.
