Discussion topic: How can I actually contact sky?
This message was authored by: Gibbsylj
Broadband keeps dropping out and I work from home.  Wondering if any coincidence that they have upgraded stuff in my area and now giving me options to cancel contract or upgrade but can anyone tell me how I can actually contact sky please?
Re: How can I actually contact sky?
@Gibbsylj
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
