Discussion topic: Horrendous wifi
This message was authored by: JMurphy97
Horrendous wifi
Despite running test and sky saying it's fine the WiFi is horrendous keeps cutting out and speed is appalling
Re: Horrendous wifi
@JMurphy97 assuming uour issue is with the WiFi in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
