4
This discussion topic has been answered Discussion topic: Home network coverage
This message was authored by: Will+iam
Why is it recent so called upgrade to fiber seems to be causing connection problems with buffering on tv late at night and connection drop out to various ancillary equipment around the house where no problems where present over the years with wired WiFi 🛜
Re: Home network coverage
@Will+iam
A poor signal is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account at about £6 per month then Sky will loan up to 3 pods as you can read about here:
The first one can be self installed while a second and third will require an engineer visit.
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
@Will+iam
@Will+iam
Presumably because the router is different.
Avatar for Will+iam
No change in router
Avatar for Will+iam
Been through all suggested Sky checks
