1
This discussion topic has been answered Discussion topic: Home brodband
This message was authored by: Emilia5
Home brodband
From 4 days I have a problem with sky brodband. Can't wach the movis on my platforms Netfix and Disney. All stops and lousing connections. Dessapointed becous i paying a lot for the home internet.
Re: Home brodband
@Emilia5
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Re: Home brodband
@Emilia5
