Discussion topic: Home broadband
This message was authored by: David813
Home broadband
Internet keeps dropping out when I do a test on the app it says there's no problems, this happens quite often
Re: Home broadband
@David813 Run the check to see if anything is showing to you!
Try running the line test here to see if any faults are found:
