Discussion topic: Hive connection
This message was authored by: Nina6
Hive connection
My electric tripped a couple of nights ago,
since my hive app isn't working.
there saying it's a connection issue but WiFi is working fine so I'm lost.
I've managed to get it reconnected but then the next day it's disconnected again
Re: Hive connection
Hi @Nina6
If all other devices are working okay I suspect it could be Hive thats the problem. Often the Hive hubs that sit between your router & the hive controller on the wall fail.
I am NOT a Sky Employee
