Discussion topic: Hive Hub connection
Message posted on 12 Oct 2026 05:48 PM
Hive Hub connection
We have had a new Sky router fitted when Sky and BT went to Fibre Optic. Sky operative was great ensuring that everthing was connected, as it was summer I forgot about the Hive hub. now it won't connect. According to Hive the following needs to be opened,
UDP port 123 (NTP)
TCP port 433 (NTTPS)
TCP5671 (AMQ{S)
Is this correct? if what how can I connect the Hive hub?
Message posted on 13 Oct 2026 10:13 AM
Re: Hive Hub connection
Hi @David022 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
