Discussion topic: Hi im internet not vork
Message posted on 16 Apr 2026 05:59 PM
Message posted on 16 Apr 2026 06:19 PM
Re: Hi im internet not vork
I presume you mean your internet isn't working?
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
