3
This discussion topic has been answered Discussion topic: Help
This message was authored by: Kw45
Help
Router not working
Re: Help
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
Re: Help
@Kw45
In what way is it not working, are there no lights lit on it at all ?
Avatar for Kw45
Re: Help
Hiya
just the red light
Re: Help
