Discussion topic: Help
Message posted on 05 Oct 2025 10:40 AM
Help
Sort the internet out
Message posted on 05 Oct 2025 11:05 AM
Re: Help
@Ski22
l’m afraid you aren’t speaking to Sky Customer Services by posting here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
You haven't said what needs sorting out so we haven't got a lot to go on!
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
