Discussion topic: Help
This message was authored by: Sonialice
Help
Please help my broadband is not working and i have followed all the steps 5 times
This message was authored by: Shell25
Re: Help
@Sonialice  it's all down
Avatar for Sonialice
Re: Help
All down?
Re: Help
@Sonialice Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
