Discussion topic: Help with signal dropping
This message was authored by: Tazzy9870
I. Having problems with my signal dropping out when im in the extension or the garden
Re: Help with signal dropping
@Tazzy9870
A wifi signal will only go so far as a poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
