This discussion topic has been answered Discussion topic: Help wifi
Message posted on 17 Sep 2025 12:57 PM
No WiFi despite running checks
Message posted on 17 Sep 2025 01:27 PM
@Ab109
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your ISP (in this case Sky).
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
@Ab109
