Discussion topic: Help slow everything
Message posted on 17 Sep 2026 05:06 PM
Why is my broadband only working with certain devices in my home it's a pain in the **bleep** I pay over the odds for this WiFi and it never works!!! Sort it out sky!!!
Message posted on 17 Sep 2026 06:55 PM
Re: Help slow everything
@Hayley204 most commonly the issue is poor WiFi signal in some areas of your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
