Discussion topic: Help needed
Message posted on 30 Jun 2025 10:02 PM
Help needed
my internet is working on iPad but not on laptop.Ive rebooted everything I need to it’s just not having it
Message posted on 30 Jun 2025 10:34 PM
Re: Help needed
@Sanny205 Was it working before, what has caused this issue that required you to re-boot the hub and then have to get item's re-connected!
Message posted on 30 Jun 2025 11:33 PM
Re: Help needed
Hi.It was working before.Just the internet icon showed no internet.Everytime I try to reconnect it says unable to connect to this network.Im on my iPad now and it’s fine.When I go to help it says to reboot etc which I have but still nothing.Sorry,I’m a bit thick so not very good with modern technology.Although if it’s gone off before I reboot everything and it works.
Message posted on 30 Jun 2025 11:40 PM
Re: Help needed
@Sanny205 Would suggest that you do the same when you are finished with the Internet this evening. If you could leave it off for an hour or overnight even better!
Message posted on 01 Jul 2025 12:12 AM
Re: Help needed
Thank you I will try that
Message posted on 01 Jul 2025 09:45 AM
Re: Help needed
Didn’t work.I give up.Thanks forvtrying though
