Discussion topic: Help alarm button on and no wifi
This message was authored by: Carolinehelpme
No wifi
help
Re: Help alarm button on and no wifi
@Carolinehelpme
The extremely hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
This message was authored by: Mr+Firas
This response from Sky is absolutely ridiculous. We had issues in out service since the end of May and it keeps going off and on. My wife works from home, and so do I at times. Yesterday the technician said it is the hot weather that is affecting some cables outside the house. Our very next door neighbour is a Sky customer and has never had any issues. The technician yesterday said he can not do anything about that without a permission from his supervisors. Later in the day, the service came back. Service was lost again in the morning today. We have been loyal customers with Sky for 13 years. Absolutely unacceptable
What response are you referring to? We are customers here like yourself.
sky broadband discussed here is a domestic servive. Sky are apparently fine with customers working from home using it for this purpose but they won't receive additional or extra support.
