Discussion topic: Hello . We've had Fiber Giga Fast installed since we started. We didn't exceed the speed limit of 30
This message was authored by: KingaWojcik
Hello . We've had Fiber Giga Fast installed since we started. We didn't exceed the speed limit of 30. I check every day. The socket that the engineer installed falls out of the wall. Is this why I pay so much money?
Re: Hello . We've had Fiber Giga Fast installed since we started. We didn't exceed the speed limit o
@KingaWojcik
Could you do a speed test using an etherneted device on fast.com with nothing else running in the background
Also if you access your hub stats as shown below can you download a file and wait 10 seconds before posting the hub stats
@KingaWojcik normally the full fibre connection required forca Gigafast service involves fitting a ONT unit (small white unit which is powered with led indicators) in your home. In. Some blocks of flats though these units are replaced by a combined unit in the comms room of the blick snd didtributed by ethernet cables is thst the typr of socket you refer to? Or are you referring to a normal copper master phone sicket which would explain the lower speeds? If you post your Sky hubs stats forum members can probably help,with the speed issue see Find your Sky Broadband router statistics
Either way you need to get Sky to get the socket repaired I can see that your post has been escalated to the Sky team who support the forum who should be in touch soon to offer you a private chat session to get this sorted. Keep an eye on the forum as if you miss the message just click the chat icon which will be added to the forum pages for you to use.saving a long phone call.
This message was authored by: Addie15
Re: Hello . We've had Fiber Giga Fast installed since we started. We didn't exceed the speed limi...
Hi there! Thank you for escalating this. We have sent an invite to @KingaWojcik.
As @Chrisee indicates, FTTP typically doesn't involve a 'socket'.  Could you elaborate, or post a picture?
Avatar for KingaWojcik
Spoiler
This is how the engineer installed such a small socket with LEDs. He mounted it too big! word, he just put it in the wall, the screws fall out by themselves when you touch the socket 🤯 I check on Fast.com and my speed is still max. 38. Where should the minimum be 600. I pay £58 a month. When he was an engineer, I showed him the speed when he asked me to go to fast.com and the speed was low, he assembled the equipment and left, and I was left with weak Internet and a high bill for it. This is very weak.
@KingaWojcik you have had an invitation to chat with Sky and they will have placed a chat icon on the forum pages for you tomuse. I suggest you do that as they can get Openreach back to check the install and they can check the speeds for you..
