Discussion topic: Having trouble in internet connection.
This message was authored by: As77
İnternet connection is drop out from 2 hours .
Re: Having trouble in internet connection.
@As77 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
