Discussion topic: Having problems with the sky pod boosters not working
This message was authored by: H4Q
Message posted on 07 Sep 2025 04:17 PM
Im having an issue with the sky pod boosters not working. I followed the instructions where you plug it into a socket half way away from the hub and the lights keep flashing white for over 5 minutes. Its the same when its pluged 1 room away and in the same room as the sky hub.
Find out more
Message posted on 10 Sep 2025 10:45 AM
Re: Having problems with the sky pod boosters not working
Hi @H4Q
Did you try following the instructions to completely reset the puck incase its got stuck?
I am NOT a Sky Employee
