Discussion topic: Hasten Go Live
This message was authored by: KayKatcs
Hasten Go Live
I've recently moved home. I checked the availability of Sky at my new place and the site showed availability. However,  my go-live has been scheduled for the 13th of June. I work from home and desperately need internet connection. I can't find help or get through to an actual person. I'm considering cancelling if I can't get assistance asap.
This message was authored by: daveNOS
Re: Hasten Go Live
@KayKatcs The date you have been given would be the earliest date that Openreach had to do the required work, cancelling now and going elsewhere will restart the process and it will be at least 2 weeks before the activation happens(with any provider that uses the Openreach network).
Working from home gives you no extra priority when your using a domestic only service.
It's also worth noting that this forum is a customer to customer help platform.
Re: Hasten Go Live
@KayKatcs  When did you place your order?  If it was in the last few days then you have the earliest appt possible, if it's that imnportant ordering prior to moving would have been preferable.
As nted by @daveNOS  WFH gives you no priority and threats to cancel will get you nowhere, cancelling will start the process all over again and your connection date will be even further in th future.
Re: Hasten Go Live
Cancellation will restart the waiting time for connection by any other ISP: typically the delay is for FTTP installation.
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
