Discussion topic: Half a job
This message was authored by: Seanvitta
Half a job
We had fibre fitted and the cable through the house but was only left enough to get as far as the radiator so have a router sat on top the radiator as he said didn't have enough cable for the job
Re: Half a job
@Seanvitta
Is this an ethernet cable with yellow plugs from an ont?  You can buy longer ethernet cables so long as they arecategory 5e at leastfrom argos, currys, pc world to allow you to put the router in a more suitable location
