Discussion topic: Had sky for 5 weeks. Never had Internet working
Message posted on 28 Dec 2025 11:15 AM
Message posted on 28 Dec 2025 11:21 AM
Re: Had sky for 5 weeks. Never had Internet working
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
Message posted on 28 Dec 2025 01:53 PM
@Billymac21 The contact number is 150 from a landline phone if it is working, or 150 from a sky Mobile if you have that also!
