Discussion topic: HIGH PING
Message posted on 14 Nov 2025 07:56 PM
HIGH PING
It was fine for two months, but unfortunately, you seem to be treating me like an old customer who doesn't need to be taken care of. It's incredibly frustrating when everything is fine all day, but in the evening, the ping becomes incredibly high, making it impossible to stream movies. The connection tests on your website are a joke. Connecting my laptop to a different provider, logging into SKY, and trying the test with your devices turned off shows... EVERYTHING IS FINE. I pay you, you provide my internet. What should I do if I don't have good internet quality from you? I'll just say that I checked everything and it works in the morning, but the ping problems and frequent buffering start in the evening.
Message posted on 31 Jan 2026 01:44 PM
Re: HIGH PING
Message posted on 31 Jan 2026 03:02 PM
Re: HIGH PING
@CMcKean You need to use everything sky Hub wise if you want or need any help from them, cable is irrelevant as long as you have one that does the job required for the connection/speed/distance in use!
Nothing wrong with an old Hub/Router it may even be better than a sky Hub to start with. Ping is not an option for checking and not needed!
Message posted on 31 Jan 2026 03:12 PM
Re: HIGH PING
When I called up they asked for pictures of the back of the hub and the Openreach box. The cable they supplied for the router is a Cat 5E and the one I had plugged in was from the puck I have for the TV as it's a Cat 7. They told me as I was using non Sky equipment that was probably the problem so I switched around the cables and, to be fair, there was a drop in ping (down from 8000 to around 5000) but still not a resolution.
I have reset the router and that helps each time for a couple of hours. However, the £20 router is better than my Sky max router for ping by a significant margin each time, it has no dropped frames or packet loss which the Sky router has.
I am going through the process at the moment and if they replace the router that may resolve the issue.
Message posted on 31 Jan 2026 03:16 PM - last edited: 31 Jan 2026 03:18 PM
Re: HIGH PING
@CMcKean If you have a ping up in that range there is way more wrong than that, ping's all though variable and equipment dependent are normally low, my standard ping is around the 20 mark!
Link from the other day, https://www.speedtest.net/my-result/d/d821a2cf-deca-4590-af67-8b12579060bf
Message posted on 31 Jan 2026 03:20 PM
Re: HIGH PING
At the moment it's down at about 120 but that's wired! So far not a great deal of help from Sky but the hubs don't do QoS as far as I'm aware.
Message posted on 31 Jan 2026 03:24 PM
Re: HIGH PING
@CMcKean The sky Max does but you have little control over that!
