Discussion topic: HELP!
Message posted on 21 Apr 2025 04:32 PM
HELP!
Having problems with broadband, it keeps dropping, we have run sky testing and no difference, can you please help
Message posted on 21 Apr 2025 04:35 PM
Re: HELP!
Have tried restarting your router to see if that does anything ?
Message posted on 21 Apr 2025 04:36 PM
Re: HELP!
@Broomer
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 21 Apr 2025 04:37 PM
Re: HELP!
@Broomer If you have done all that you think can be then call sky,
