Discussion topic: Guest wifi
This message was authored by: LSCW
Guest wifi
I have an Airbnb and want to create a separate secure wifi network. My intention is to add a separate router hard wired to the sky router and then a wireless access point on a lan cable cable to the new router.
Re: Guest wifi
@LSCW  If you're going to get a new router just replace the sky hub altogether otherwise you're going to cause a double nat issue.
It woukld need to be DHCP Option 60/61 compatible fir UK FTTC connections.
