Discussion topic: Guest pass for router
Message posted on 03 Apr 2025 05:42 PM
Need to set up guest password for router how do I do it.
Message posted on 03 Apr 2025 05:46 PM
Re: Guest pass for router
There isn't any model of Sky Hub which has that functionality.
Message posted on 03 Apr 2025 05:50 PM
Thank you ,will I have to have another router?
Message posted on 03 Apr 2025 05:59 PM
If you want Guest functionality, yes. Alternatively, adding a separate wireless access point might serve the same purpose.
Message posted on 03 Apr 2025 06:22 PM
I don't want guests using my broadband, read on Internet you can set up guest password on router so they can't see what my device's are.
Message posted on 03 Apr 2025 06:43 PM - last edited: 03 Apr 2025 06:45 PM
OK: that would require a router with dedicated Guest functionality (technically it's using VLANs behind the scenes to separate traffic)
