Discussion topic: Got no wifi
This message was authored by: Zoe150
Got no wifi
Got no wifi
Re: Got no wifi
@Zoe150 wrote:
Got no wifi
@Zoe150
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
