Discussion topic: Gigafast+ existing customers
Message posted on 30 Jul 2025 09:12 AM
With the recent introduction of gigafast+ I was interested at looking to see if this is something I could get. I'm currently on full fibre gigafast and when I check my upgrade options Sky say I'm on the fastest available package.
However when I look on cityfibre's checker, it says I should be able to get 5gbps through sky. Is gigafast+ only for new customers or will I be able to upgrade to this at some point?
Message posted on 30 Jul 2025 09:35 AM
Re: Gigafast+ existing customers
Are you on full fibre via openreach? If so I believe there is currently no way to switch from one provider to another you would need to already be supplied by city fibre to get access to the new products
Message posted on 30 Jul 2025 10:15 AM
Yeah I think I am currently supplied by open reach, would need to check the ONT when I get home.
If I am with open reach, do we know if it will be possible to switch in the future?
Message posted on 30 Jul 2025 10:21 AM
Unfortunately operational details are still extremely scarce.
Message posted on 11 Aug 2025 08:19 PM
FWIW, I upgraded from Openreach-based Gigafast to Cityfibre-based Gigafast+ and the new line was installed automatically as part of the order.
However, for me the newer Gigafast+ packages showed up when running the postcode checker on the Sky website. I didn't have to do anything special.
Pretty sure you have to be in a Cityfibre area that is XGS-PON enabled for the faster packages - not all Cityfibre areas were on this, including my area, but Cityfibre have been upgrading their hardware for existing deployments like mine. If the Cityfibre checker says you can get it, I would have thought you are in an XGS-PON enabled area though.
Sky Q, Sky Full Fibre 2.5 Gigafast+ with Sky XER10 (white cylindrical Gigafast+ Hub)
Message posted on 12 Aug 2025 07:14 AM
@KillerCars that is exactly correct City Fibre are still upgrading their network from G-PON to XGS-PON which is required for the two Gigafast+ tiers.In June they reported 85% of the network had been upgraded at that date with the balance due to be completed "this summer" see https://cityfibre.com/news/cityfibre-unveils-new-5-5gb-wholesale-product-its-fastest-ever
