Discussion topic: Gigafast+ Hub Issues
Message posted on 20 Jul 2026 11:52 PM
I wonder if someone's had a similar experience?
I have the 1gb sky connection and I got the option to upgrade to the Gigafast+ Hub. I took sky up on the offer but have had no luck with getting the connection.
I've contacted sky 5 times now, and have made no progress. They've sent me 2 gigafast hubs, neither which have worked. The ONT gets an orange light on data whenever I connect it. The old router has a green light.
I've contacted technical support 5 times and I feel like I'm going in circles. The same trouble shooting each time and it just isn't working.
They're just not listening to me, and it's terrible frustrating.
i just want to go back to the old sky hub router and this upgrade process has been a farce.
Has anyone had similar issues?
I feel like an engineer would have to come out and have a look but they're not even offering that.
Message posted on 21 Jul 2026 12:04 AM
Re: Gigafast+ Hub Issues
Hi,
I'm getting my hub+ on Friday so I will let you know if mine works straight out the box or if I need to do anything different.
Message posted on 21 Jul 2026 07:02 AM
@CorcaighSky if multiple unitsxare failing there is highly likely to be an issue with the connection rather the hub. Try replacing the cable connecting the hub to the ONT these are simply an Ethernet cable which you can buy literally anywhere and they do fail. The lights on the ONT are diagnostic as explained here https://www.sky.com/help/articles/optical-network-terminal I have never seen one showing an orange light but models vary.
Message posted on 21 Jul 2026 10:44 AM
I've tried a few different Ethernet cables. Always an orange light on the ONT data light unfortunately.
Message posted on 21 Jul 2026 12:57 PM
@CorcaighSky re[ort the issue to Sky as if the ONT is the issue you require an engineer from Openreach or City Fibre which they can arrange.
Message posted on 22 Jul 2026 11:13 AM
Still no luck with this.
Tried the giga fast + hub again. Worked for an hour before failing again.
Old hub/router works perfectly.
I'd caution anyone against upgrading at this stage.
Message posted on 22 Jul 2026 12:11 PM
Message posted on 22 Jul 2026 01:14 PM
It's so frustrating. The service isn't working and they're doing nothing to rectify the matter.
Just telling me to restart the router or swap the Ethernet cables around.
They're telling me there's nothing wrong with the line but when I do the self check it says there's something wrong.
I've been left in a limbo with no solution, and I'll be charged for the equipment even though I was told not to send it back for the moment.
Message posted on 20 Aug 2026 06:01 PM
This is still an ongoing issue.
Sky sent out an engineer and replaced the ONT. Worked for a few days and the. Stopped again.
I get the white light on the router but no internet.
Sky and the engineer can't figure out what's wrong?
Has anyone had similar and found the solution?
