Discussion topic: Getting broadband fitted
Message posted on 20 Jun 2025 02:36 PM
Hi there, I’m getting new WiFi installed that I’m supposed to fit myself. It’s a copper wire connection, but I’ve just realized I don’t have any internal wiring in my house to connect to the box. Will I still be able to install it myself, or will I need someone to come out and fit the wiring first?
Thanks in advance for your help!
Message posted on 20 Jun 2025 02:39 PM
Re: Getting broadband fitted
Hi @Jodie80
Do you not have a BT/Openreach telephone socket anywhere in the house?
Message posted on 20 Jun 2025 02:42 PM
No not that I can see. What would this look like?
Message posted on 20 Jun 2025 02:52 PM
Something like this @Jodie80
No I don't have one of these
Message posted on 20 Jun 2025 02:53 PM
Is the house a new build or not? Has it ever had broadband before that you are aware of?
Message posted on 20 Jun 2025 02:54 PM
No it's not a new build and I'm not sure what was there before sorry
Message posted on 20 Jun 2025 02:56 PM
Okay its likely you will need a new socket/line installed. This usually can only happen once the activation date has passed and you report to Sky that you cant connect
Message posted on 20 Jun 2025 03:03 PM
Okay no bother. Thanks for your help.
Message posted on 20 Jun 2025 05:10 PM
@Jodie80 They do sometimes hide the socket's so be sure to look in cupboards etc.
