Discussion topic: Full fibre 100
Message posted on 27 Sep 2026 03:08 PM
Full fibre 100
Hi is anyone else having issues with full fibre 100 only Working in one room at the speed it should work at ie the same room as the router
Message posted on 27 Sep 2026 03:21 PM - last edited: 27 Sep 2026 03:24 PM
Re: Full fibre 100
100Mbs is speed delivered to the Hub over optical fibre and ethernet cable, not WiFi from it. All WiFi loses speed through walls.
For the 100Mbs FTTP product (and if the WiFi Max subscription supplement is on the broadband account) the 'guaranteed' WiFi speed is 10Mbs
Message posted on 27 Sep 2026 04:23 PM
Re: Full fibre 100
A poor signal is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account at about £6 per month then Sky will loan up to 3 pods as you can read about here:
The first one can be self installed while a second and third will require an engineer visit.
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
