Discussion topic: Full fib
This message was authored by: Mick140363
Full fib
Not te received a new router only a cat 6 cable delivered
Re: Full fib
@Mick140363 Good sign that is all you need to change over the system from a copper connection to a FF Full Fibre, if you have the black upright sky Broadband Hub then you are good to go, have linked the hubs below if you need to go look!
This message was authored by: P123gat
Re: Full fib
Just had full fibre installed and cannot install Wi-Fi onto my tv it keeps saying password incorrect
Re: Full fib
@P123gat
Have you checked that you are not entering a zero instead of a letter O or a number 1 instead of a letter l or vice versa ?
Re: Full fib
Yes tried various permutations probably ring sky tomorrow thanks for help
This message was authored by: simon194
Re: Full fib
@caesarome wrote:
@P123gat
Try doing a full reset on the hub.  You might have been given  hub that someone had changed the password from the default.
I had the same happen when I had a faulty hub replaced.
_____________________________________________________
