Discussion topic: Frequent loss of connection with Sky Max Hub but no issue when reverting to original Sky router
This message was authored by: Chris280
I "upgraded" to the Sky Max Hub several months ago and have encountered loss of connectivity between my Sky Q box (and other devices) and the hub several times per day. I've followed all advice including device resets, reconnecting everything in order via WPS and so on.
Today I decided to switch back to my original Sky hub and, after a quick update of the SSID in the router admin panel, I am experiencing zero connectivity issues.
Does this seem like a faulty Sky Max Hub or am I essentially paying a premium for a worse solution?
This message was authored by: Tom-W19
Re: Frequent loss of connection with Sky Max Hub but no issue when reverting to original Sky router
Hi @Chris280
Your post has been escalated to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the chat bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
Avatar for Chris280
Thanks @Tom-W19
So after several hours yesterday and more time this morning I'm no closer to a resolution and an Engineer has been booked for the 19th.
It does seem a lot of messing about when I explianed that I had zero issues with my old hub and now that I've "upgraded" to the Max hub I can no longer use the mini box as this causes the connection to the main box to drop and, even when i do have a connection, the wifi strength across all my devices is so much worse than before.
An engineer, additional boosters, a potential mini box replacement (all of which have been mentioned by the team in chat) seems pretty unnecessary to me when all i really want is to do get rid of the "upgrade" and just use what i had before - which was totally fine.
Is it a case of needing to jump through the hoops so that when the engineer inevitably tells me that the max hub isn't really compatible with Sky Q, mini boxes and bossters, I have to start this all over again?
