Discussion topic: Frequent disconnect
This message was authored by: Rambo3
Frequent disconnect
Hello, my broadband is frequently disconnecting. And the signal is very weak in the upstairs. Can you please provide us a solution for this please
Re: Frequent disconnect
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
If you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
