Discussion topic: Frequent Internet disruption
Message posted on 14 Apr 2025 11:35 AM
Message posted on 14 Apr 2025 11:38 AM
Re: Frequent Internet disruption
@Jey
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services.
This should determine if there's an identified fault affecting multiple households.
