Discussion topic: Freely tv
Message posted on 13 Jun 2026 08:52 PM
Freely tv
My freely tv won’t connect, it’s hit and miss with sky broadband. It was fine with my BT broadband?
ssneveith connecting to social media, it says to contact my broadband provider???
Message posted on 14 Jun 2026 07:03 AM
Re: Freely tv
@Broadband17 wrote:My freely tv won’t connect, it’s hit and miss with sky broadband. It was fine with my BT broadband?
Presuming this is due to poor wifi try the following, although plugging an ethernet cable between the two would solve the issue.
Have a look at the following to see if they can resolve your problem easily, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
