Discussion topic: Flashing orange light in “internet” and orange light “voice”
Message posted on 21 Dec 2025 05:31 PM
Internet not working, did a restart. Have two orange light on "internet" and "voice".
Message posted on 21 Dec 2025 05:46 PM
Re: Flashing orange light in “internet” and orange light “voice”
@Station
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
