Discussion topic: Flashing Lan light
This message was authored by: McRory
Message posted on 07 May 2025 08:38 PM
Flashing Lan light
Why does my lan light keep flashing?
Message posted on 07 May 2025 08:43 PM
Re: Flashing Lan light
@McRory The lan light flashes to indicate that data is being sent from your Hub!
Message posted on 07 May 2025 08:53 PM
Does this mean everything is as it should be?
Message posted on 07 May 2025 08:57 PM
@McRory With regards to the flashing light on a ONT from the hub, yes, that is what it does, dimmer it is faster the data is going.
