Discussion topic: File Upload Issues
Message posted on 04 Feb 2025 09:49 AM
File Upload Issues
I'm a photographer and I'm required to upoad images to clients, usually in jpeg format, with a file size not exceeding 3Mb. I use Photo Mechanic to upload these images in batches.
After moving home, I signed up for Sky Gigafast broadband, mainly due to the high download/upload speeds when sending images.
I've now found that I can only send 2 images concurrently using Phot Mechanic, and after that, the image sending stalls, which was never the case before.
I've tried using my mobile router as well as WiFi at other venues, and the problem doesn't occur, which leads me to believe that my Sky broadband is the issue.
I've disabled Sky Broadband Shield, but this has had no effect.
Any suggestions would be much appreciated.
Message posted on 04 Feb 2025 11:09 AM
Re: File Upload Issues
Hi @HMFCALUM
Does your connection still function when the upload stalls? Does the upload ever resume?
