Discussion topic: Fibre
Message posted on 26 Mar 2026 11:07 AM
Fibre
I haven't had an internet connection for 3 hours, I've done 10 tests, restarted the modem 10 times, I've done everything possible and nothing has worked.
Message posted on 26 Mar 2026 11:38 AM
Re: Fibre
@Victor14 if you run the service checker in the My Sky app using a mobile connection it should take you through a few steps before booking an engineer. If it doesnt call Sky to report the fault.
Message posted on 26 Mar 2026 02:15 PM
Re: Fibre
and without calling support there is no way to check what the problem is if my internet is not working very, very well.
Message posted on 26 Mar 2026 02:49 PM
Re: Fibre
Actually @Victor14 Sky's online service checker does a pretty solid job of diagnosing faults and assigning the correct engineer sufficently accurately that Openreach gives it direct access to their engineering diaries. The customer service reps use a similar set up if you call in.
