Discussion topic: Fibre to WiFi propagation
Message posted on 09 Mar 2026 04:35 PM
Message posted on 09 Mar 2026 05:19 PM
Re: Fibre to WiFi propagation
@Jamie1476 extending the fibre feed is not straight forward but you can ise a longer Ethernet cable from the ONT to the hub allowing it to be moved. These are cheap to buy and you do not need anything special.
Message posted on 09 Mar 2026 08:07 PM - last edited: 09 Mar 2026 08:12 PM
At least one online supplier lists an ONT relocation kit with back-to-back optical couplers and a compatible length of pre-terminated fibre-optic cable: actually using this is potentially problematic because technically the connection belongs to network provider as far as the ONT itself.
As @Chrisee indicates, moving the Hub by using a longer ethernet cable is simpler, and there's no loss of speed over Cat5e (possibly Cat6A if the service is 2.5Gbs or 5Gbs on CityFibre infrastructure)
