Discussion topic: Fibre not working
Message posted on 10 Aug 2026 08:25 PM
Fibre not working
Fibre not working
Message posted on 10 Aug 2026 08:27 PM
Re: Fibre not working
As you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
