Discussion topic: Fibre keeps dropping out
Message posted on 14 Oct 2024 08:05 PM
sky fibre keeps dropping out very weak signal and can't reach all the house even with booster
Message posted on 14 Oct 2024 09:34 PM
Re: Fibre keeps dropping out
@Richie+3414 suspect it is nothing to do with your fibre broadband but simply you need more than two wifi sources in your home. It is a common issue. If you buy. Sky WiFi max you can call Sky who will areange for an engineer to come out who can supply two extra extender pods. One thing about extenders or boosters is they need to good connection tomthe hub tomwork so must be placed roughly halfway between the hub and where you need the boost. Place them in an area with poor wifi and they are likely to make things worse.
Message posted on 14 Oct 2024 10:06 PM
Thanks for your reply, I have had an engineer out already and I already have a booster which they set up was working fine for about 2 hours but again now keeps dropping out completely and keeps says no connection. Think it's time to look elsewhere
