Discussion topic: Fibre is useless
This message was authored by: nathangrimmer
Fibre is useless
Since upgrading to sky fibre a few months, I'd happily go back to old broadband, the constants no connections now is for to five times a day, and also a with sky glass it takes that out also. Anyone else find this worse than the old broadband?
Re: Fibre is useless
That gets reported here several times a day: in some properties it does appear the Max Hub has poorer WiFi performance than the Sky Broadband Hub.
Given Sky is probably sending out thousands a week it may only be a small percentage of users affected, but it's undoubtedly extremely annoying.
Avatar for nathangrimmer
Level 3 icon
I have the older black router from a couple of years ago, maybe need the newer one, WiFi coverage is rubbish
