Discussion topic: Fibre extension cable
This message was authored by: DJASZ
Hi. I am looking for some advice, what kind of cable would i need to get to extend my on the wall fibre cable?? It is quite short and wont reach to where i need to sit it. Thank you
Re: Fibre extension cable
@DJASZ Are you talking about the Ethernet cable back of the hub connected to port 4 wan, or a rj11 vdsl cable connected to a Openreach master phone socket, either one are available from the likes off amazon, just get the length that you need.
@DJASZ
In theory (and for educational purposes only) a length of simplex single-mode OS2 fibre terminated with SC APC plugs plus an SC APC junction box might serve to relocate an ONT.
Openreach officially disapproves of such solutions.
