6
This discussion topic has been answered Discussion topic: Fibre connection
This message was authored by: bluenose1000
Fibre connection
Hi,
I'm looking to upgrade my broadband to Ultrafast or full fibre and wanted to know how to find out what connection method would be used for my property before signing up ( ie from a telegraph pole or underground ) ? Many thanks
This message was authored by: cookiemonsteruk Answer
Re: Fibre connection
@bluenose1000
Overhead feed with no anticipated issues
What does it say at the end off the wbc fttp install stage ie 1 or 2
@bluenose1000
Could you enter your full address below and post the table and notes after removing your address from the image
Avatar for bluenose1000
@bluenose1000
That's great, thanks.  stage 1
@bluenose1000
Should be a lead time of 12 days between ordering thru sky and installation
Brilliant, thanks again for the swift reply ! 👍
