		Discussion topic: Fibre connection fault ?
	This message was authored by: Bod6
		Message posted on 02 Sep 2025 04:02 PM
Hello
To connect my tv to stream tv I need to switch the router off and on again to connect. The bt fibre connection hub constantly shows a red light for a fault which may be the cause. Speed tests show the system is at the correct speed but it is obviously not correct
can you assist ?
duncan
