Discussion topic: Fibre cable
Message posted on 11 Jun 2026 06:45 PM
Fibre cable
I just received my fibre conversion kit which consists of one short fibre cable I’m assuming this will connect the new outlet to my router. My current outlet /socket is 3-4 meters away from my router and the cable is fixed along the skirting board. (Done by sky engineer). Will they supply a longer cable as I don’t want to move my router
Message posted on 11 Jun 2026 06:50 PM
Re: Fibre cable
@GKW If you want t longer ethernet cable from the router to the ONT you will have to buy one, sky only supply the one length
Message posted on 11 Jun 2026 07:43 PM
Re: Fibre cable
What should I order. I'd like to have it before they install. Want to make sure I have the correct cable
Message posted on 11 Jun 2026 07:48 PM
Re: Fibre cable
@GKW Cat5E at a minimum, that will give you a gigabit connection, you can get cat 6 or 7 if you're future proofing, but for now it may be overkill.
Message posted on 11 Jun 2026 08:11 PM
Re: Fibre cable
Thank you. Very helpful
Message posted on 11 Jun 2026 08:27 PM - last edited: 11 Jun 2026 08:29 PM
Re: Fibre cable
Cat6A is fine for any speed which the national optical network is ever likely to deliver.
Note that all ethernet is 8-strand copper: the optical connection ends at the ONT.
